Tailscale обрыв соединение
Доброй ночи, кто может подсказать с чем могут быть связаны обрывы связи
tailscale-1  | boot: 2025/11/29 02:19:55 Running 'tailscale up'
tailscale-1  | 2025/11/29 02:19:55 Start
tailscale-1  | 2025/11/29 02:19:55 Backend: logs: be:Убрал fe:
tailscale-1  | 2025/11/29 02:19:55 control: client.Login(0)
tailscale-1  | 2025/11/29 02:19:55 control: client.Shutdown ...
tailscale-1  | 2025/11/29 02:19:55 control: mapRoutine: exiting
tailscale-1  | 2025/11/29 02:19:55 control: updateRoutine: exiting
tailscale-1  | 2025/11/29 02:19:55 control: doLogin(regen=false, hasUrl=false)
tailscale-1  | 2025/11/29 02:19:55 control: authRoutine: exiting
tailscale-1  | 2025/11/29 02:19:55 control: Client.Shutdown done.
tailscale-1  | 2025/11/29 02:19:55 health(warnable=login-state): error: You are logged out. The last login error was: fetch control key: Get "https://controlplane.tailscale.com/key?v=130": context canceled
tailscale-1  | 2025/11/29 02:19:55 control: control server key from https://controlplane.tailscale.com: ts2021=[fSeS+], legacy=[nlFWp]
tailscale-1  | 2025/11/29 02:19:55 control: RegisterReq: onode= node=[mtX7s] fup=false nks=false
tailscale-1  | 2025/11/29 02:19:55 control: RegisterReq: got response; nodeKeyExpired=false, machineAuthorized=true; authURL=false
tailscale-1  | 2025/11/29 02:19:55 health(warnable=login-state): ok
tailscale-1  | 2025/11/29 02:19:55 health(warnable=not-in-map-poll): ok
tailscale-1  | 2025/11/29 02:19:55 control: netmap: got new dial plan from control
tailscale-1  | 2025/11/29 02:19:55 active login: убрал
tailscale-1  | 2025/11/29 02:19:55 Switching ipn state NoState -> Starting (WantRunning=true, nm=true)
tailscale-1  | 2025/11/29 02:19:55 magicsock: SetPrivateKey called (init)
tailscale-1  | 2025/11/29 02:19:55 wgengine: Reconfig: configuring userspace WireGuard config (with 0/2 peers)
tailscale-1  | 2025/11/29 02:19:55 wgengine: Reconfig: configuring router
tailscale-1  | 2025/11/29 02:19:55 wgengine: Reconfig: user dialer
tailscale-1  | 2025/11/29 02:19:55 tsdial: bart table size: 5
tailscale-1  | 2025/11/29 02:19:55 wgengine: Reconfig: configuring DNS
tailscale-1  | 2025/11/29 02:19:55 dns: Set: {DefaultResolvers:[] Routes:{} SearchDomains:[] Hosts:3}
tailscale-1  | 2025/11/29 02:19:55 dns: Resolvercfg: {Routes:{} Hosts:3 LocalDomains:[]}
tailscale-1  | 2025/11/29 02:19:55 dns: OScfg: {}
tailscale-1  | 2025/11/29 02:19:55 monitor: gateway and self IP changed: gw=убрал self=убрал
tailscale-1  | 2025/11/29 02:19:55 peerapi: serving on http:/убрал
tailscale-1  | 2025/11/29 02:19:55 peerapi: serving on http://убрал
tailscale-1  | 2025/11/29 02:19:57 netcheck: DetectCaptivePortal(found=false)
tailscale-1  | 2025/11/29 02:19:57 magicsock: home DERP changing from derp-0 [0ms] to derp-26 [67ms]
tailscale-1  | 2025/11/29 02:19:57 magicsock: home is now derp-26 (nue)
tailscale-1  | 2025/11/29 02:19:57 magicsock: adding connection to derp-26 for home-keep-alive
tailscale-1  | 2025/11/29 02:19:57 magicsock: 1 active derp conns: derp-26=cr0s,wr0s
tailscale-1  | 2025/11/29 02:19:57 derphttp.Client.Connect: connecting to derp-26 (nue)
tailscale-1  | 2025/11/29 02:19:57 control: NetInfo: NetInfo{varies=false hairpin= ipv6=false ipv6os=true udp=true icmpv4=false derp=#26 portmap= link="" firewallmode=""}
tailscale-1  | 2025/11/29 02:19:57 health(warnable=warming-up): ok
tailscale-1  | 2025/11/29 02:19:57 magicsock: endpoints changed: убрал (stun), убрал (local), убрал (local)
tailscale-1  | 2025/11/29 02:19:57 Switching ipn state Starting -> Running (WantRunning=true, nm=true)
tailscale-1  | 2025/11/29 02:19:57 health(warnable=no-derp-connection): ok
tailscale-1  | 2025/11/29 02:19:57 [RATELIMIT] format("health(warnable=%s): ok")
tailscale-1  | boot: 2025/11/29 02:19:57 Startup complete, waiting for shutdown signal
tailscale-1  | 2025/11/29 02:19:57 magicsock: derp-26 connected; connGen=1
tailscale-1  | 2025/11/29 02:21:55 control: map response long-poll timed out!
tailscale-1  | 2025/11/29 02:21:55 Received error: PollNetMap: context canceled
tailscale-1  | 2025/11/29 02:21:55 control: lite map update error after 2m0.001s: Post "https://controlplane.tailscale.com/machine/map": context canceled
Tailscale v1.90.9 в lxc самохостинга установлен в runtipi , соединение есть в районе 10-15 секунд потом обрубается. Если перезапустить Tailscale также соединение 10-15 сек могу подключаться удаленно потом обрубается, пробовал что говорит ИИ не помогает
tailscale-1  | 2025/11/29 02:23:55 control: lite map update error after 2m0.001s: Post "https://controlplane.tailscale.com/machine/map": context canceled
tailscale-1  | 2025/11/29 02:23:55 Received error: PollNetMap: Post "https://controlplane.tailscale.com/machine/map": context canceled
tailscale-1  | 2025/11/29 02:25:55 control: map response long-poll timed out!
tailscale-1  | 2025/11/29 02:25:55 control: lite map update error after 2m0.001s: Post "https://controlplane.tailscale.com/machine/map": context canceled
tailscale-1  | 2025/11/29 02:25:55 Received error: PollNetMap: Post "https://controlplane.tailscale.com/machine/map": context canceled
tailscale-1  | 2025/11/29 02:27:55 control: map response long-poll timed out!
tailscale-1  | 2025/11/29 02:27:55 control: lite map update error after 2m0.001s: Post "https://controlplane.tailscale.com/machine/map": context canceled
tailscale-1  | 2025/11/29 02:27:55 Received error: PollNetMap: Post "https://controlplane.tailscale.com/machine/map": context canceled
этот сайт хостится на сервисах амазон
проверь у себя доступность AWS тут
Вот так, только у меня нет понимания что значат эти результаты или что тут надо сделать)
Похоже на блокировку.
На днях магистральщики перестраивали оборудование, были сбои и появились доп. фильтры.
Можно попробовать добавить фильтр по хостам сканера, Руслан скидывал скрипт
Это? на опенврт пойдет?
Да это, там скрипты под микрот, если openwrt можно загрузить списки из csv файла, то пойдет
root@OpenWrt:~# /usr/bin/check_skipa.sh
=== Skipa Status ===
table inet skipa_table {
        set skipa_set {
                type ipv4_addr
                flags interval
                elements = { 5.143.224.100/30, 5.143.224.104/30,
                             5.159.97.203, 5.178.87.167,
                             5.188.159.228, 31.131.251.106,
                             31.131.251.235, 31.131.255.205,
                             31.131.255.206, 31.131.255.207,
                             31.131.255.208, 31.131.255.209,
                             31.131.255.210, 31.131.255.211,
                             31.131.255.212, 31.131.255.240,
                             37.9.13.54, 37.9.13.84,
                             37.9.13.105, 37.9.13.217,
                             45.92.176.94, 45.92.176.129,
                             45.92.176.143, 45.92.176.144,
                             45.92.176.145, 45.92.176.205,
                             45.92.177.113, 45.92.177.127,
                             45.92.177.237, 45.93.20.45,
                             45.93.20.79, 45.93.20.103,
                             45.93.20.104, 45.93.20.109,
                             45.93.20.126, 45.93.20.148,
                             45.93.20.229, 45.141.86.171,
                             45.146.167.56, 45.146.167.68,
                             45.146.167.105, 45.146.167.237,
                             62.84.116.11, 62.84.116.13,
                             62.84.116.34, 62.84.116.219,
                             62.84.116.237, 62.113.99.65,
                             77.223.102.84, 77.223.102.101,
                             77.223.102.191, 77.223.103.45,
                             77.223.103.53, 77.223.120.227,
                             80.93.187.17, 80.249.131.92,
                             82.148.21.205, 85.142.100.0/24,
                             85.175.69.50, 85.175.147.234,
                             89.169.28.191, 89.169.28.210,
                             89.169.28.214, 91.122.177.241,
                             92.38.153.0/24, 92.124.109.218,
                             92.223.103.144, 94.25.46.114,
                             94.26.228.18, 94.26.228.205,
                             95.143.190.169, 95.143.190.179,
                             95.143.191.147, 95.143.191.223,
                             95.143.191.245, 95.167.62.66,
                             95.167.62.82, 95.167.82.26,
                             95.167.87.66, 95.167.133.10,
                             95.167.148.18, 95.167.186.2,
                             95.167.197.242, 95.167.198.186,
                             95.167.199.34, 95.167.199.90,
                             95.167.200.10, 95.189.36.106,
                             176.100.243.247, 176.208.65.146,
                             176.208.67.114, 176.208.69.226,
                             176.208.70.162, 176.208.79.82,
                             176.210.118.218, 176.211.46.130,
                             176.211.47.122, 176.211.48.242,
                             176.211.51.218, 176.211.56.130,
                             176.211.103.178, 176.211.103.202,
                             178.185.133.251, 178.185.170.42,
                             178.185.202.130, 178.185.202.162,
                             178.185.216.114, 178.185.228.58,
                             178.185.234.162, 178.185.235.58,
                             178.185.235.74, 178.185.238.154,
                             178.185.238.178, 178.185.239.50,
                             178.185.239.58, 178.185.241.98,
                             178.185.241.114, 185.224.228.0/24,
                             185.224.230.0/24, 188.68.217.207,
                             188.246.224.80, 193.168.46.143,
                             194.26.25.137, 212.41.10.41,
                             212.41.12.45, 212.41.12.46,
                             212.41.12.47, 212.41.12.48,
                             212.41.13.23, 212.41.13.24,
                             212.41.13.25, 212.41.26.138,
                             212.67.10.218, 212.67.11.37,
                             212.67.11.128, 212.67.11.136,
                             212.67.11.167, 212.67.11.227,
                             212.67.11.233, 212.67.11.234,
                             212.164.59.250, 212.192.158.0/24,
                             213.59.217.242, 217.65.82.18 }
        chain input_skipa {
                type filter hook input priority -100; policy accept;
                ip saddr @skipa_set counter packets 7 bytes 316 drop
        chain forward_skipa {
                type filter hook forward priority -100; policy accept;
                ip saddr @skipa_set counter packets 0 bytes 0 drop
✓ Таблица skipa существует
Количество IP в наборе:
1
Логи:
Sun Nov 30 02:10:52 +05 2025: Ошибка добавления адреса: 85.142.100.2/32
Sun Nov 30 02:10:52 +05 2025: Успешно добавлено 144 адресов
Sun Nov 30 02:10:52 +05 2025: Создана цепочка input_skipa
Sun Nov 30 02:10:52 +05 2025: Создана цепочка forward_skipa
Sun Nov 30 02:10:52 +05 2025: === ОБНОВЛЕНИЕ ЗАВЕРШЕНО ===
root@OpenWrt:~#
Вроде сделалась эта штука, только даст она какой то эффект?
