Ошибка при создании PBS Custom Widget для Glance
В общем с использованием Grok получилось что-то такое:
        - type: custom-api
          title: PBS Backup Snapshots
          cache: 12h
          url: 'https://10.10.11.116:8007/api2/json/admin/datastore/s3-yandex/snapshots'
          allow-insecure: true
          headers:
            Accept: application/json
            Authorization: 'PBSAPIToken=myuser@pam!api:123'
          options:
            # Maximum storage size in bytes (default: 100 GB)
            maxSize: 107374182400
          template: |
            <style>
            .pbs-container { font-size: 0.9em; }
            .backup-header, .backup-row { display: flex; border-collapse: collapse; align-items: center; gap: 10px; padding: 4px 0; }
            .backup-row { text-transform: lowercase; border-bottom: 1px solid var(--color-border); }
            .backup-header { text-transform: uppercase; font-size: 1em; font-weight: bold; color: var(--color-primary); border-bottom: 1px solid var(--color-primary); margin-bottom: 2px; }
            .col { min-width: 0; margin-right: 15px; }
            .col-id { flex: 1; }
            .col-type { flex: 1; }
            .col-comment { flex: 3; }
            .col-size { flex: 1.5; text-align: right; }
            .col-time { flex: 1.5; }
            .total-summary { font-weight: bold; margin: 10px 0; padding: 5px; background: var(--color-background-secondary); border-radius: 4px; }
            .stat-header { display: flex; justify-content: space-between; align-items: flex-end; font-size: 0.85em; margin: 10px 0; }
            .stat-percent { font-weight: 500; }
            .progress-bar { width: 100%; height: 8px; background: var(--color-background-tertiary); border-radius: 4px; overflow: hidden; margin-top: 4px; }
            .progress-value { height: 100%; background: var(--color-positive); width: var(--percent, 0%); transition: width 0.3s ease; }
            .progress-value-notice { background: var(--color-negative); }
            .usage-label { text-align: center; margin-top: 5px; font-weight: 500; }
            .server-type { padding: 2px 6px; border-radius: 4px; text-transform: lowercase; background: var(--color-background-tertiary); }
            .timestamp { cursor: default; }
            </style>
            {{ if eq .Response.StatusCode 200 }}
            <div class="pbs-container">
            {{- $backups := .JSON.Array "data.#" -}}
            {{- $sortedBackups := sortByFloat "backup-time" "desc" $backups -}}
            {{- $bytesInGB := toFloat 1073741824 -}}
            {{- $maxSize := .Options.FloatOr "maxSize" 107374182400 -}}
            {{- $totalSize := 0 -}}
            {{- range $sortedBackups -}}
            {{- $totalSize = add $totalSize (.Int "size") -}}
            {{- end -}}
            {{- $usedPercentFloat := mul (div $totalSize $maxSize) 100 -}}
            {{- $usedPercent := printf "%.1f" $usedPercentFloat -}}
            {{- $usedPercentInt := toInt $usedPercentFloat -}}
            <div class="backup-header">
            <div class="col col-id">ID</div>
            <div class="col col-type">TYPE</div>
            <div class="col col-comment">COMMENT</div>
            <div class="col col-size">SIZE</div>
            <div class="col col-time">TIME</div>
            </div>
            {{- $id := .String "backup-id" -}}
            {{- $type := .String "backup-type" -}}
            {{- $comment := .String "comment" -}}
            {{- $size := .Int "size" -}}
            {{- $time := .Int "backup-time" -}}
            {{- $formattedSize := printf "%.2f GB" (div $size $bytesInGB) -}}
            <div class="backup-row">
            <div class="col col-id">{{ $id }}</div>
            <div class="col col-type"><span class="server-type">{{ $type }}</span></div>
            <div class="col col-comment">{{ $comment }}</div>
            <div class="col col-size">{{ $formattedSize }}</div>
            <div class="col col-time"><span class="timestamp" data-ts="{{ $time }}"></span></div>
            </div>
            {{- end -}}
            <div class="total-summary">
            Общий размер: {{ printf "%.2f GB" (div $totalSize $bytesInGB) }} ({{ $usedPercent }}% от {{ printf "%.2f GB" (div $maxSize $bytesInGB) }})
            </div>
            <div class="stat-header">
            <span class="stat-percent">{{ $usedPercent }}%</span>
            <span>Заполненность хранилища</span>
            </div>
            <div class="progress-bar">
            <div class="progress-value{{ if ge $usedPercentInt 80 }} progress-value-notice{{ end }}" style="--percent: {{ $usedPercentInt }}"></div>
            </div>
            <div class="usage-label">Макс. размер: {{ printf "%.2f GB" (div $maxSize $bytesInGB) }}</div>
            <script>
            document.addEventListener('DOMContentLoaded', function() {
            document.querySelectorAll('.timestamp').forEach(function(el) {
              const ts = parseInt(el.dataset.ts) * 1000;
              const date = new Date(ts);
              el.textContent = date.toLocaleString('ru-RU', {
                year: 'numeric',
                month: '2-digit',
                day: '2-digit',
                hour: '2-digit',
                minute: '2-digit',
                second: '2-digit'
            </script>
            </div>
            {{ else }}
            <p>Ошибка загрузки: {{ .Response.Status }}</p>
            {{ end }}
Проблема в том что в выводе в браузере получаю ошибку:
Get "https://10.10.11.116:8007/api2/json/admin/datastore/s3-yandex/snapshots": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
Сам PBS использует s3 от yandex, туда всё спокойно загрузилось и если дернуть запрос через curl то всё работает меньше чем за секунду:
curl -w "\n%{time_total}\n" -k -H "Accept: application/json" -H 'Authorization: PBSAPIToken=myuser@pam!api:123' "https://10.10.11.116:8007/api2/json/admin/datastore/s3-yandex/snapshots"
В общем что я делаю не так? Проблема действительно в запросе, или там что-то еще может быть? Гугление по теме увеличения таймаута лично мне ничего не дало(
